2008 A C 500 won't start
Old Nov 30, 2011 | 01:17 PM
Bobboy's Avatar
Default 2008 A C 500 won't start
The cat has only 34 hrs. on it. Mainly use it for hunting and because I live in the north east........light snow plowing. The battery was weak ao I had my son put a new one in. Upon hooking up the cables, he had attached the pos one and when he attemped to attach the neg cable it sparked. He mentioned it to me and noticed he attached the cables backwards!! The neg cable was never attached but he had touched the neg side of the battery a couple of times. After reversing the cables, the cat spins over well but appears to have no spark. CDI burnt?????
Old Nov 30, 2011 | 07:44 PM
Fossil's Avatar
"If you haven't any charity in your heart, you have the worst kind of heart trouble." ~Bob Hope
Did you check all the fuses?
Old Dec 1, 2011 | 11:24 AM
Bobboy's Avatar
pulled them all out, and did a continuity check on them, all were fine. Pulled out all the diodes, relays.....everything looked fine. The damn thing spins over using the key just great. It acts like there is no spark or it's not getting any fuel. It ran fine when I parked it a couple of months ago. Fuel tank is full. It was never started nor even keyed on until after the connection was corrected. Thanks for askin'
Old Dec 1, 2011 | 11:49 AM
Fossil's Avatar
Did you test it to see f there actually is spark and check for a wet spark plug to make sure it is getting fuel?
Old Dec 4, 2011 | 06:44 AM
Kerbbirds's Avatar
pull spark plug and ground it to motor then turn it over , see if there is spark, might try a new plug while your at it, if your gonna let it sit for months, need to get some stabil in the gas
Old Dec 5, 2011 | 11:18 AM
Bobboy's Avatar
Kerbbirds,
Hey thanks for the suggestion. I had already pulled the plug, cleaned it up and grounded it. It was wet, so I know it was gettin' some fuel. It has a great spark. I am gonna get into the fuel system next.
It did fire, but now won't stay runnin'. gotta be either a plugged fuel line or maybe a bad diaphram??? At least it does fire. I thought it might have been the CDI.
Thanks.
Old Dec 8, 2011 | 07:03 AM
Kerbbirds's Avatar
might need a good carb cleanin, take carb float bowl off, remove all jets, air screw , blow through all passage ways with carb cleaner and compressed air, Ill bet pilot jet is plugged, if youll run seafoam in your gas it will keep carb clean, wont clean it whe its already gunked up though
Old Dec 8, 2011 | 08:55 AM
Bobboy's Avatar
Hey Kerbbirds, thanks again for the great suggestion. I definitely will run some seafoam through it. I did manage to get the darn thing going over the weekend without replacing anything. I'm guessin' you were right about the carb. That's what I get for not usin' the thing. Thanks again. Merry Christmas!!
Old Dec 8, 2011 | 10:46 AM
Fossil's Avatar
Check to make sure the fuel tank vent line (which runs up and ends under the instrument pod) is not plugged or kinked.
Old Dec 8, 2011 | 11:20 AM
Bobboy's Avatar
Thanks Fossil, I didn't think to check that, but I will. Have a great Christmas and get dirty!!!
