raptor sprockets ?
Old Mar 16, 2001 | 09:01 AM
rraptorr13's Avatar
What are people running for sprockets? I read that 13/41 will eliminate the !st being a little to tall problem (up form 12/40 stock)
Old Mar 16, 2001 | 09:25 AM
ERICsRAPTOR's Avatar
Isn't it 13/40 stock?
Old Mar 16, 2001 | 11:19 AM
Mudrat454's Avatar
13/40 is stock. I am running 12/42 now with the factory tires and I like it. Am mounting up my 22" RAz'rs this afternoon to try this weekend. I will see how I like the gearing with the taller tires.
Old Mar 16, 2001 | 08:30 PM
HELMET660's Avatar
i put an 11/40 on w/ the stock tires and was right where i wanted to be for woods/climbing.
i've since put 22/razrs on the rear and it bumped me back into the "to tall" dillema. the extra ground clearance w/ the 22's is great, but to get it where i want it i'll have to go to a 42 in the rear and shim the skid plate loosing some of the
ground clearance. youll also notice w/ the 22's,
your quad feels "jacked up" in the rear. i had to take some off the preload in the rear to make it sit level again.
Old Mar 17, 2001 | 04:10 AM
AlaskaTRX's Avatar
What manufacturer did you buy your sprockets from, guys?
Old Mar 17, 2001 | 04:51 AM
Mudrat454's Avatar
What kind of skid plate do you have? I have a PRM and my 42 fit fine, I saw where someone else put a 43 on with the PRM skid without shimming it.
I used a Renthal sprocket.
Old Mar 17, 2001 | 01:15 PM
DcRAPTOR's Avatar
Go with the sidewinders they are by far the best but the price is a little more
Old Mar 17, 2001 | 10:32 PM
ZEBRATRAILER's Avatar
I run a sprocket specialties 504-12 for general riding, and a 504-11 for the dunes. the 11 tooth sprocket is real hard on chains, but you have a wide range of low end gearing with a limited top end. The 12 tooth will give you a handfull of bike (with a stock swingarm) and still give the big dogs a run for their money.
bmxatv10
Oct 14, 2022 06:23 PM
buddieboy
Dec 9, 2016 05:50 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
