400EX- K&N Dyno-Jet
Old Mar 16, 2001 | 12:18 PM
RotGutBottom's Avatar
Hey fella's
Have you guys ever installed one of these? How do these work better than stock? What power gains should I expect? I just put on a K&N Air Filter and outerwear (removed box lid), and a White Bro's E slip on- (this rocks!). I've seen a pretty good power gain so-far.
Also- can someone explain to me what these "jets" do?.. and what the number (size) means? I keep seeing posts about changing the size... what number is stock? how does changing the size affect performance?
Thanks for your help!
Old Mar 16, 2001 | 10:01 PM
Dirtddemon's Avatar
It not worth the 140 bucks they run at a shop. The bigger the number the more gas it flows into the carb.
Old Mar 16, 2001 | 11:44 PM
pudjumper's Avatar
RotGut...I agree with dirt save your money. You can buy jets for $4 or so. It's a marketing scam.
Old Mar 16, 2001 | 11:50 PM
RedDog400ex's Avatar
I have a K&N jet kit I am running a 155 main jet with K&N, supertrapp exhaust, 3 inch hole in airbox lid. The stock jet in the 2000 400ex is a 148, you should be running about a 155 or 160 which comes in the kit. It is very easy to change the jet. Turn off the gas, on the bottom of the carb there is a bolt take that out, careful a little gas will come out, then feel up inside there and what you feel is the jet, then unscrew that and put in the dynojet.
junglerat
Jan 19, 2007 12:12 PM
onesavage
Jan 17, 2007 02:08 PM
650T
Mar 19, 2006 04:48 PM
LivinInVegas
Nov 27, 2004 09:10 PM
