raptor 350
Old Jan 12, 2012 | 08:35 AM
chasehoe's Avatar
Default raptor 350
i just bought a 2004 yamaha raptor 350.
and it was rebulit with a standard piston with less then an hour on it.
how long should it run?
how good of a machine are they?
Old Jan 13, 2012 | 04:36 PM
Koopa's Avatar
Is addicted to 4 wheel'n!
They are built off of the old warriors. Do regular maintenance and oil changes and you'll be riding it for a very long time. IMO they are one of the most reliable machines out there.
Old Jan 13, 2012 | 05:52 PM
chasehoe's Avatar
What all is regular maintenance?do you beat on them because I sure do?
Old Jan 13, 2012 | 06:59 PM
Koopa's Avatar
Change oil often. No longer than 30 hours or so. Clean air filter after ever few rides depending on condition. Anything will die if abused but, it can take a hard ride.
Old Jan 14, 2012 | 05:08 PM
chasehoe's Avatar
and i have normal schaeffer oil 10w30 should i use that or synthetic?
do i need to oil the air filter after i clean it?
Old Jan 14, 2012 | 07:09 PM
Koopa's Avatar
You must use an oil designed for motorcycles. These oils are designed for engines where the clutch rides in the same oil. Bel-ray, yamalube or such. Synthetic is not necessary in my opinion. I think alot are blends. And yes, you want to oil you filter after you clean it. The oil helps catch fine dust particles and keeps the engine good and clean.
Any more questions ya have lay them out man. Here to help. If you do these things we are talking about that raptor will scream for years to come.
Old Jan 14, 2012 | 07:33 PM
chasehoe's Avatar
and the owners manuel says to clean the oil filter i thought i jst changed it?
could i change the oil with the 10w30 just till i get the atv stuff since it was rebuilt?
so as long as its good with wet clutch it doesnt matter what oil?
Old Jan 16, 2012 | 09:22 PM
Raptor450's Avatar
You don't want to use the automotive oil, it could cause your clutches to slip. so don't put the wrong oil in there. It doesn't matter what brand of oil you use, like said above as long as it's for wet clutches. I always ran Yamalube in my Yamahas. As for the oil filter, I just changed mine after evry couple of oil changes and I never had any problems. That engine should last many years with no problems if you treat it right. Weak links on these machines are not the engine but the rear axle bearings, front a-arm ball joints, and the upper engine mounts. also keep the chain from getting too loose so it won't pop off and bust your engine cases and you should be all set!
Old Jan 20, 2012 | 05:28 PM
chasehoe's Avatar
Well the oil drain plug is striped the head of it.
And I try using a chisel and e erything and I cant get it.what do I do?
Old Jan 21, 2012 | 10:22 PM
chasehoe's Avatar
Well I got it out.
bmxatv10
Oct 14, 2022 06:23 PM
black_thunder
Sep 22, 2015 07:59 PM
Alex Rodak
Sep 13, 2015 12:30 AM
Alex Rodak
Sep 12, 2015 09:39 AM
Alex Rodak
Sep 11, 2015 11:42 PM
