→ Blaster tech →
Old Jan 13, 2012 | 04:59 PM
TacticalRedneckofKentucky's Avatar
Default → Blaster tech →
ok, have an 01 blaster. I put on wheels/tires on the back, accidentally messed up the chain adjuster, but i finally figured it out and got it adjusted again.
Now. When i pull the clutch in its still pulling. Ive already adjusted it several times at the handel bars.
Looking down, theres usually 2 bolts. I usually losen 1, adjust the other, and tighten the other.
But i dont see that here. Cant figure out why it keeps coming out and how to adjust it majorly..
The fine tuning up top aint working...
Any help
Old Jan 13, 2012 | 05:20 PM
HMT Racing's Avatar
Ok first of all how much slackdo you have in your clutch handle ? 1/8" to 1/4" slack should be perfect. Now what type of oil did you put in the transmission? It must be wet clutch oil only. Any other type will not work and can cause the simptoms you are describing.
HMT Racing's Avatar
Ok first of all how much slack do you have in your clutch handle ? 1/8" to 1/4" slack should be perfect. Now what type of oil did you put in the transmission? It must be wet clutch oil only. Any other type will not work and can cause the symptoms you are describing.
Old Jan 13, 2012 | 06:47 PM
no slack i can remember, and i always use the yamalube stuff.
Old Jan 13, 2012 | 08:08 PM
HMT Racing's Avatar
Man now you got me stumped too, (thinkin!!!!!)
Old Jan 13, 2012 | 08:48 PM
Terrellster's Avatar
For the more in depth adjustment, pull the clutch cover (Buy a new gasket before you do this). The adjustment bit you seek is inside that cover..... You will want to adjust it carefully so you don't over do it. You want it tight so you don't have to get in there again soon also.
Old Jan 13, 2012 | 11:00 PM
papa hogg scoot's Avatar
Loved
Community Favorite
No slack you said???? You will need slack [freeplay] to make sure the clutch is fully released!!!![engaged to pull].
Ahtatu
Sep 28, 2015 12:14 PM
r1pilot83
Sep 27, 2015 07:38 PM
XxS0ccerstarxX
Sep 22, 2015 08:07 AM
rgjackson
Sep 17, 2015 11:21 AM
nastyblaster100
Sep 13, 2015 01:19 PM
