prospector track tension
Old Jan 24, 2012 | 06:56 PM
joelrainville's Avatar
Default prospector track tension
i have a 2011 ranger with prospctor tracks and i think they are to tight i would like to know if anyone knows the tension that they should be at ?
Old Jan 25, 2012 | 11:31 PM
switzomatic's Avatar
I'll have to check the manual that came with mine but I think it's like 1/2 inch or so. They don't need much sag but definitely shouldn't be tight or they'll stretch and wear prematurely.
Old Jan 26, 2012 | 06:25 PM
Mongrol's Avatar
"Official Site Skeptic"
I've had tracks on 3 different machines and find the factory specs and ways of measuring "SUCK".
I've found the most efficient way of doing it is like this;
Hold the inside and outside of the track with your hands (in line with the center of the drive sprocket) and pull up. When properly set, it shouldn't lift more than 1/16". To double check, and fine tune the setting, pull the track sideways (back and forth) across the top of the drive sprocket. There should be resistance enough that it slides ok but not real easy.
This will get you close to the factory setting and make for fun riding.
Hope this helps.
Old Feb 2, 2012 | 09:09 PM
Default thanks
thanks i will try that and post my results
Oct 10, 2015 10:20 AM
MikeyBoyesq
Sep 22, 2015 10:02 AM
raman8tor
Sep 20, 2015 07:35 AM
bvolks
Sep 13, 2015 12:57 PM
MikeyBoyesq
Sep 7, 2015 10:44 PM
