OIL TEMP LIGHT PROB
Old Mar 17, 2001 | 04:02 AM
sand45's Avatar
my riding partner and i both have ds650,when riding at the dunes my oil tem light has came on quite a few times.My partners oil tem light has never came on, we ride the same way and just as hard.After i let it sit for about 5min and start the bike everything is fine the lights off.Anyone have the same problem? or any idea on what up?
Old Mar 17, 2001 | 12:28 PM
clif's Avatar
Is your fan comming on?I had the same thing happening on my new DS.The oil temp light kept comming on.It turned out to be, my fan was bad.They put a new one on, and have had no more problems.
Old Mar 17, 2001 | 12:39 PM
ScoobyDFW's Avatar
The indicator light is both a low oil pressure sensor and a coolant temperature sensor. I could be wrong, but I believe the indicator light might cycle from steady-on to steady-off every second or so if the coolant temperature gets too high. If it is low oil pressure I believe the indicator light either starts to flicker and eventually will be steady/full on if the pressure gets low enough.
The indicator light is nothing to take lightly!
The 2000 models (manufacturing date < June 2000) have been known to have bad oil pressure switches. This is a recall with a new part number for the oil pressure switch and was fixed in the 2001 model ((manufacturing date > June 2000). I ended up replacing the oil pressure switch myself by buying a BMW F650 part. Even with a good oil pressure switch, the light will flicker if the oil gets low or the oil has not been changed in a while, or if you are running too lean with elevated temperatures and near continuous fan running. If you changed the oil and didn't bleed the system properly this could be a problem also. If the fan is NEVER running then the DS will get too hot and the oil pressure will drop. Some of us have had fan problems.
I had air trapped in my cooling system and came close to an overheat.
Old Mar 17, 2001 | 09:09 PM
sand45's Avatar
THINKING ABOUT IT MORE MY FAN WOULD COME REGULARLY
BUT NOW I HAVE NOT HEARD MY FAN COME ON FOR AWHILE. WHEN MY LIGHT DOSE COME ON OR OFF THERS IS
NO FLICKERING THERE IS A STEADY RED LIGHT. MY DS IS A 2001 MODLE.IS THERE ANY WAY TO TEST MY FAN TO SEE IF IT IS WORKING? THANK YOU CLIFF& SCOOBY
panicmanic
Sep 28, 2015 12:59 PM
MooseHenden
Family ATVing Photos
Sep 20, 2015 04:14 PM
Halffast17
Sep 11, 2015 02:30 PM
Steeldon
Sep 9, 2015 09:38 AM
MikeyBoyesq
Sep 7, 2015 10:44 PM
