adding a universal oil cooler to a 300ex?
Old Mar 17, 2001 | 11:17 AM
Mike300ex's Avatar
Have any of you added an oil cooler to your 300ex? Where did the lines connect to?
I've been thinking of adding an oil cooler but dont want to spend 200 bucks for one. I've noticed that most auto parts stores sell universal oil coolers of just the right size (for next to nothing...$30) but i have no idea of where the oil cooler lines would connect to. Anyone know?
I've seen somewhere of an atv shop that makes a oil filter cover that has holes drilled/tapped for oil cooler lines but i'm not sure who this is. Anyone know?
Thanks in advance
Old Mar 17, 2001 | 12:57 PM
StrokerEX's Avatar
hey Mike, how do you like yer supertrapp ids2 exhaust? I'm getting one for my 300EX but can't decide which one.
Old Mar 18, 2001 | 09:23 AM
Mike300ex's Avatar
I love it. When i bought my 300ex (used) it came with a DG RCM race pipe/silencer setup on it which was WAY too loud.
Although i dont have a stock pipe to compare it to (in sound or power) i can say that it sounds alot better (much sportier, unlike that harley sounding DG pipe) than the DG pipe, and it definately runs way better now.
I also liked the way supertrapps included everything needed including a new bracket for the rear brake cylinder so it wasn't so close to the exhaust.
Right now i'm only running 7 discs. I think it comes with 10-12 discs (i can't remember for sure) and you can install anywhere from 4 to 12 of them. 7 seems like a good medium for me between sound and power.
Old Mar 18, 2001 | 09:53 AM
94DGblaster's Avatar
i am running the IDS with 12 disk.
more disk more power. So i went with all of them
Old Mar 18, 2001 | 10:44 AM
pacrat's Avatar
Mike, one of my friends owns a 300EX with an oil cooler. It taps into the steel oil line that comes out of the case, then goes to the head. He says it greatly reduced the power fade on hot days, and no more clutch fade also. He used a large oil/trans cooler from a car at a junk yard, it cost around $20 I think. It looks like a small radiator, similar to what is on the 400EX, but much larger, it is not the round tube and fin design which I have heard are not as efficient. Hope this helps, Bryan
Old Mar 18, 2001 | 11:40 AM
FourtraxEX's Avatar
Hey Mike, I was just wondering, when you mentioned the rear brake reservoir relocator bracket. Where were you supposed to relocate it? The only place I found to put it was to slide it into the frame towards the airbox. I was wondering where you put yours? When me and my father replaced my '95 300EX's stock pipe, this Supertrapp is recognizingly louder, but compared to my friends Cobra piped warrior, it's as quiet as a mouse. As for the oil cooler, I'm not sure about it. I would like to find one cheap as well because I'm on a slightly older motor and I can feel the loss of power in the heat. So keep me posted on your project. Email me at Mx300EX@aol.com.
Old Mar 18, 2001 | 07:33 PM
Mike300ex's Avatar
When i do finally get the oil cooler project done i'll post some pics and info here for sure. Next weekend i'll be going to see what oil cooler i can find.
As for the brake res. bracket...you have it exactly how i do. It basically moves it in more. The other pipe i had on there (when i bought it) was very close to the brake res. I'm suprised it didnt melt it.
If you have any more questions let me know.
fredrikrosen
Sep 28, 2015 09:58 PM
2many2ride
Sep 27, 2015 04:35 AM
WilliamBos
Sep 22, 2015 04:07 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
Elkaholic
Sep 6, 2015 02:44 PM
