2006-400ATV starting difficulties
Old Feb 7, 2012 | 05:42 PM
bazzman12's Avatar
Default 2006-400ATV starting difficulties
Will not start with electric start. Engine rotates when trying but that's it. This happens with first start of the day or when it is cold. I can pull start it usually on the first try. After engine is warmed up it will then start with electric. Any suggestions before I sink too much money into something it ain't. LOL
Old Feb 10, 2012 | 11:41 PM
swampyjunior's Avatar
Three things that come to mind for hard starting are choke, valve adjustments and a dirty carb.
I believe the 06 has an electric choke? But check to make sure it works properly.
Usually if it needs cleaning that takes care of #3 as well.
Having valve tappets out of adjustment can also cause this but you would need like 1500mi or so on the machine.
Hope this helps.
Old Feb 11, 2012 | 10:01 AM
weez440's Avatar
sounds like a bad battery to me. but while you are at it i would clean the carb and also put in a new plug.
MikeyBoyesq
Nov 27, 2020 02:44 PM
Mkp
Mar 28, 2020 03:50 AM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
Tree Farmer
11
May 12, 2000 01:18 AM
