'11 500 HO starter noise
Old Feb 11, 2012 | 12:40 PM
cbrandon's Avatar
Default '11 500 HO starter noise
Is it just mine or do all The Polaris starters sound like they stick just slightly when started? The dealer acted as if it was no big deal. It has done this since brand new. Just wondering if it needs to be looked at or if it a common thing on The Polaris starter.
Old Feb 11, 2012 | 12:54 PM
irinman2424's Avatar
mine has been the same way since day 1 (2011 sportsman 500 HO) a friend of mine has a 2010 550 XP and it does it too
Old Feb 11, 2012 | 01:06 PM
cbrandon's Avatar
Ok, thanks for The info. I guess its just how they are atleast I won't worry about it anymore. Much appreciated.
Old Feb 11, 2012 | 01:08 PM
The 500 Sportsmans don't have the torque of the bigger engines to kick back the starter bendix at times and hangs up! On every new one we sold I started telling customers to start with their left hand and BLIP the throttle as soon as it started which will torque the bendix back in the case away from hanging up on the flywheel. Crappy I know,but prolongs the life of the bendix if you do this! OPT
Old Feb 11, 2012 | 07:36 PM
500H.O.'s Avatar
my 2012 does it and my 2002 did it also, just the way they sound.
Old Feb 11, 2012 | 07:46 PM
All most all the 500s do it! Just blip the throttle when it first starts and less wear and tear on the bendix! Don't just try to start it like you do a car! OPT
Old Feb 11, 2012 | 09:43 PM
cbrandon's Avatar
Thanks for The info but what do you mean "start it like a car" ?
Old Feb 12, 2012 | 09:06 AM
When you just have your foot on the brake and turn the key and start! A lot of people start the 500 the same way:just have it in park or neutral and turn the key and then hear the grinding after it starts,but if you just get used to this procedure like I did after servicing up and working on so many of em,and just use your left hand to turn the key to start and blip the throttle when it does, the bendix won't hang up and grind against the flywheel! OPT
Old Feb 12, 2012 | 12:37 PM
cbrandon's Avatar
Ok, that makes sense I just wanted to be sure I understood what you were saying.
Old Feb 12, 2012 | 12:42 PM
I'm OLD! Sometimes I don't even make sense of what I'm saying! OPT
