new chain & sprockets - to tight to ride
Old Feb 26, 2012 | 03:02 PM
kpnkidhppy's Avatar
Default new chain & sprockets - to tight to ride
just put new stock 11/40 sprockets on my daughters 01 trailboss 325
had heck of a time getting them on and i know they are way to tight to ride, any clue why?
previous owner had 12/42 sprockets and they were shot.
also put on new o-ring chain, new is 39 links old one was 40links.
ist time owning a polaris and need some info
Old Feb 26, 2012 | 03:34 PM
Scooter86's Avatar
Knows Old ATV Questions!
Sounds like the old ones were really loose. Sounds silly, but did you loosen the adjuster as far as it will go? I wonder if they didn't put larger sprockets on to add tension to a chain that was to long and/or worn out. Do you know what it takes stock? ALso where you at in NY? I am from the Rochester area.
Old Feb 26, 2012 | 03:45 PM
kpnkidhppy's Avatar
turned the adjuster back as far as it would go, put the chain on the front sprocket first and only way I could get it on was to put chain on rear sproket and then bolt to axle with a lot of tugging and swearing. Its way to tight and I dont want to let my daughter ride it yet.
Iam over near Utica
Old Feb 26, 2012 | 04:33 PM
user493's Avatar
Moto Psycho
Maybe your new chain is a link too short.
Old Feb 26, 2012 | 05:58 PM
kpnkidhppy's Avatar
i emailed the place I bought it from to ask that question but have heard nothin back yet. Just thought Id ask out here cause I'm not familiar with polaris, thanks
Old Feb 26, 2012 | 05:59 PM
HMT Racing's Avatar
Yea sounds like you need to add a helf link. Or drop one tooth on the rear sprocket
Old Feb 26, 2012 | 06:05 PM
HMT Racing's Avatar
Half link
Old Feb 26, 2012 | 06:18 PM
kpnkidhppy's Avatar
not a big deal adding to chain?
always had shaft drives before
Old Feb 26, 2012 | 06:59 PM
If you have the 11 tooth front and 40 tooth rear standard sprockets then a 78 link(39 links as you said which is 78 individual links!) chain should fit with NO problems unless someone cut it short or you have other problems! This is the chain length called for on this model! OPT
Old Feb 26, 2012 | 08:45 PM
kpnkidhppy's Avatar
so if my sprockets and chain are correct, i have rotated the axle to the loosest position, any other thoughts on what I may be doing wrong?
all the brackets holding tranny seem to be correct, and the machine worked fine before I changed sprockets. Also can I just add a link with out any issues?
Thanks
