Help Installing FCR carb
My friend Just got his motor Back from LRD yesterday, We put the motor back in, then we put the FCR 39mm carb on. The problem is the gas tank sits on top of the carb and it won't go down all the way. The carb seems to sit way to high. PLease give me any tips or tricks on how we have to mount it?
Thanks
Thanks
This caught my attention because I just bought a 39mm FCR for my 400EX and haven't installed it yet. Maybe he's trying to put it on the 2001 Raptor that's listed at the bottom of his post. Anyways; since we're on the topic, are there any jetting problems that people have encountered with the FCR? I have a 10.6:1 86mm piston, high rev CDI, HRC cam, K&N, e-series silencer and elevation is about 800' to 1000' above sea level. I bought mine from Curtis Sparks and they said that they would send extra jets along with it- but they didn't actually send them.
When I was running the 39mm FCR on my 426 set up I was using a 162 main jet, needle on third position. I am between 4 and 5 K feet..
I am running a full Big Gun, 450/451 cam, 11:1 piston, and K&N w/modified airbox...very mild match porting... cdi module....
Now I Run a 440 by LRD with 11:1 coated piston, and a very free flowing port job, and I run the same carb with a 172 main and needle on 4th position. I think I will be moving up to a 175 main jet when I go to the dunes... It is running very good now. I think I am right in the ball park for my area...
I'm running the XR cam, 87mm 10.8:1 JE, mildly ported head, modified airbox, and modified stock exhaust system.
I am currently running a 170 main, 52 pilot, and 3rd notch on the needle. I also modded the accelerator pump to kill a hesitation when the throttle was wicked open.
It seems that you need to be 1 or 2 main jet sizes larger than with the stock carb. This is due to less vacuum pulling fuel thru the main of the larger carb.
Perfect fit and excellent gains throughout the powerband... A definite thumbs up on this carb.
Does anyone else have the metallic rattle when cold? Almost sounds like piston slap, but it's the roller mounted slide in the carb.
GregM
Mar 6, 2018 06:53 AM
