Klf300 sputtering need help plz
Old Apr 19, 2012 | 10:33 AM
harveje's Avatar
Default Klf300 sputtering need help plz
90ish new to me
Fixed petcock
Cleaned carb
Will crank and run but spits sputters pops backfires
Now if I turn the lights on it smoothed out and runs pretty good
Never seen this issue
Voltage reg get real hot too
Thank you for your help
Old Apr 19, 2012 | 10:36 PM
papa hogg scoot's Avatar
Loved
Community Favorite
Have you check charing rate? I f you turned lights on an ran better atv maybe over charging...When the lights was turned on that took some voltage away...Checking rate....
Old Apr 19, 2012 | 10:38 PM
Loved
Community Favorite
Also if over charging to much volts to the cdi could cause misfires...
Old Apr 28, 2012 | 09:09 PM
harveje's Avatar
Default Thanks
Finally got back to work on the ride.
Evidently the charger (dead battery) was putting out to many volts and causing the issue. Changed chargers and it will run but still has a little pop or sputter every now and then.
New issue is the bike is not charging the battery so I'm on the hunt now to find out why.
Again, Thanks for the help
ReconBayou
Oct 31, 2022 05:37 PM
ltrmc02
Aug 22, 2021 02:34 PM
Bernhard
Sep 25, 2015 12:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
Ricardo Covarrubias
Sep 17, 2015 08:28 AM
