Klf300 sputtering need help plz
Old 04-19-2012, 10:33 AM
harveje's Avatar
Default Klf300 sputtering need help plz
90ish new to me
Fixed petcock
Cleaned carb
Will crank and run but spits sputters pops backfires
Now if I turn the lights on it smoothed out and runs pretty good
Never seen this issue
Voltage reg get real hot too
Thank you for your help
Old 04-19-2012, 10:36 PM
papa hogg scoot's Avatar
Have you check charing rate? I f you turned lights on an ran better atv maybe over charging...When the lights was turned on that took some voltage away...Checking rate....
Old 04-19-2012, 10:38 PM
Also if over charging to much volts to the cdi could cause misfires...
Old 04-28-2012, 09:09 PM
harveje's Avatar
Default Thanks
Finally got back to work on the ride.
Evidently the charger (dead battery) was putting out to many volts and causing the issue. Changed chargers and it will run but still has a little pop or sputter every now and then.
New issue is the bike is not charging the battery so I'm on the hunt now to find out why.
Again, Thanks for the help
ReconBayou
10-31-2022 05:37 PM
ltrmc02
08-22-2021 02:34 PM
Bernhard
09-25-2015 12:45 PM
Nosniborpapa
09-19-2015 07:07 PM
Ricardo Covarrubias
09-17-2015 08:28 AM
Quick Reply: Klf300 sputtering need help plz
