2000 blaster won't start
i presume you've checked for spark and fuel? just asking cause you haven't stated that yet or anything that would tell us what you've checked for or not. such as, petcock valve lined up for carb to receive fuel. ignition switch on and kill switch deactivated.
Sorry , never had a blaster before, nor a 2 stroke . Fuel is good , spark plug is 2 months old from what I was told . I turn on key , turn switch to run , turn on fuel , pull out choke , and kick . I get nothing . The oil injection has been removed , but the TORS system is still hooked up . The block ontop of the carb is a little loose , not sitting flush on carb .
spark plugs can foul out after many hours of use or after a few minutes. you really need to check for spark. if you have spark, and are wondering if it's a fuel issue, you can CONSERVATIVELY spray a shot of ether in to the intake and kick the quad over. also, grab a compression gauge and check it to see how much you got.
Checked everything , and all is good . Decided to just unplug the TORS control under the hood . The bike started first kick . Runs no problem , but won't idle very good , and sputters . Any suggestions ?
First thing that comes to mind, is to go ahead and run it without the TORS system if it will accelerate past chugging idle. Mine is disabled and I love it.
I think the switch on your TORS is on the right hand lever. the park brake cam will have a small switch that is activated by it's movement.... find the switch, and see what it does. If it's "closed" or open with the park brake on.... then decide how to proceed to bypass/disable it.
To bypass the TORS, unplug it at the wiring harness and ground it out somewhere.
Have you cleaned the carbs? That would be my first place to go.
