Tires for ranch work?
Old Apr 25, 2012 | 01:00 PM
Sparky101's Avatar
Default Tires for ranch work?
Hi,
I just bought a used Kawasaki Prairie 700 to use on our ranch and the tires that came with it wore out in 5 minutes, so I'm looking at buying 4 new tires.
The atv is used mainly on hard-packed dirt roads, gravel and pastures with steep hills (and a little bit on pavement when there is no way around it). To complicte matters, I would also like to drag my arena with the atv and the dirt in the arena is about 3 inches deep (though I could give up this use if there isn't a tire that would work for this and also last on the roads).
So, any suggestions on what tires I should get, or what to look for in a tire? And where to get them online.
Thanks in advance!
P.S. I'm an atv newbie so please be gentle and use atv newbie words :-)
Old Apr 25, 2012 | 08:45 PM
Rancher247's Avatar
I think that the Maxxis Bighorns would suit your needs. Not an overall aggressive tread pattern, good for a variety of terrains.
Old Apr 25, 2012 | 10:44 PM
user493's Avatar
Moto Psycho
Mud tires have deeper lugs that should take a long time to wear out but they're fairly expensive and generally ride a little rougher. Every tire is a compromise.
Old Jul 26, 2012 | 06:13 AM
overstockwheels's Avatar
Post Re:
The BFG AT comes to mind. Its 3 ply sidwall, has a crazy load capacity and it nice and quiet on the road. Im on the OEM ATs right now, usually run those down a bit then get something new.
I have land with dirt, caliche, crushed concrete, gravel, rock, wood, barbed wire, etc. 3 ply sidewalls in most AT/Mud tire work very well. Nitto, Toyo, General, BFG.
Old Jun 3, 2013 | 04:07 PM
j_one85's Avatar
you can check out GPS Offroad Products, they have a tire that's similar to the Maxxis Bighorn, the brand is a Sun-F 12 ply Run Flat option, strong load capacity, strong sidewall, the tire was tested and approved by the U.S. Military, GPS Offroad Products also has more UTV tires to choose from.
txkevin
Sep 21, 2015 02:02 PM
mic214
Aug 11, 2015 07:27 AM
Mattius
Jul 11, 2015 10:44 PM
kwackermann
Jun 24, 2015 10:18 AM
ragewraps
May 27, 2015 08:07 AM
