2001 yamaha warrior help!!!
Old Jun 20, 2012 | 01:13 PM
sirconnorman's Avatar
Default 2001 yamaha warrior help!!!
hey guys i bought a 2001 yamaha warrior off craigslist for $700 knowing it wont start. i just put in a brand new battery thinking that was the problem when nothing happens. when i turn the key no lights come on or anything and when i press the start button nothing happens no clicks or anything. we got it running about a week ago by pushing it and popping the clutch but i need the electric start to work. im need ideas soon please help i dont wanna waste my money on parts it doesnt need i looked at the wiring and it is rough but all there and in tact please help!
Old Jun 20, 2012 | 01:49 PM
Raptor450's Avatar
There is a fuse under the left rear fender. I would check that 1st.
Old Jun 20, 2012 | 01:55 PM
i forgot to mention that but i did check that and its in great shape, when i bought it from the guy he said it needed a new battery and starter but a starter wouldnt be the reason for the lights not turning on
Old Jun 20, 2012 | 08:57 PM
95wolv's Avatar
Did you verify the key switch and the wiring from it are good, since nothing comes on when you turn the key on, I would start there and work my way to the battery. there is a fuse, as mentioned before, plus a starter relay that runs power to the starter circuit, that should "click" when you turn the key on or push the start button. Maybe time to buy a good manual with an electrical diagram, or see if you can google one off the internet, would save you a lot of wire tracing.
Old Jun 30, 2012 | 05:23 PM
DanWarrior's Avatar
I had a similar problem before and it turned out to be the stator, they do go bad on these warriors.
Old Jul 2, 2012 | 09:53 AM
ok thanks alot guys this really helped but now i have 2 more problems that i cant seem to figure out...
1. i cleaned the carb twice very well but it wont idle without the choke halfway in, i cleaned the jets well and i tried adjusting the idle screw but that didnt serm to do much
2. i went to bleed the rear brakes the other day and the reservoir is filled and its flowing to the foot brake pump but not to the disc brake. i pump and pump and pump then crack loose the bleeder screw and there is bo pressure please help thank you so much
Reactant
Mar 30, 2022 02:08 AM
STLyamwar
Jul 25, 2020 04:44 AM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Aug 6, 2015 05:29 PM
Ashley S
Jul 31, 2015 09:46 AM
