grizzly 350 power
hey all, so im 13 yrs old and thinking about getting a grizzly 350. how good are these in mud? how fast will they go? and is there enough power for pulling a largish tree on a trailer? thanks
I just bought a 2007 4x4 350 Grizzly, The ATV pulls well and has a 1,100lb towing capacity which is not bas since a 700 Grizzly is rated at 1,300lbs.
I towed some very heavy trailer loads of hard wood with it and it handled it no problem.
This model has a speedo and does only 45 mph comfortable but will go faster but the motor sure is screaming much after that. I think its geared and clutched on the low end side to compensate for having no low range option.
What I like about it is , the mid size chassis for manoeuvrability and the machine is so plain jane simple, its almost just a gas and go ATV will much less maintenance and thing to worry about.
Have not had it long and in real bad mud.
No Diff lock option but I sure can,t see it ever running out of wheel turning power in any type of conditions.
My only up grade will be a set of mudlite XL tire with taller lugs but I will stay with the 25" tire size even though 26" would probably be no problem for this ATV.
RticKwad
Jul 21, 2015 03:00 PM
