06 raptor chain and sprockets. When to change them?
Old Jul 10, 2012 | 09:45 AM
Webb700's Avatar
Default 06 raptor chain and sprockets. When to change them?
Hey just wondering if anyone could tell me if I need to replace the sprockets on my 06 raptor. Whenever I slow down or use the brakes there's a clicking noise and it sounds like its coming from the front one but I'm not positive. Any help would be greatly appreciated.
Old Jul 12, 2012 | 11:41 AM
Webb700's Avatar
Default when to change sprockets and chain?
Hey I have an 06 raptor 700 and I was just wondering when I need to change the sprockets? Whenever I hit the brakes or slow down the front one is making a clicking noise. Any help is appreciated
Old Jul 12, 2012 | 11:50 AM
scootergptx's Avatar
Supersock
Hired Gun!
Do the teeth look rounded? Depending on what the ones you have are made of, that could make a difference too.
How is the tension on the chain?
A new setup is a lot cheaper when you're doing it before the chain hits the case.
Old Jul 12, 2012 | 03:40 PM
TacticalRedneckofKentucky's Avatar
t
Thats when a case saver comes in handy
Old Jul 13, 2012 | 12:55 PM
geoman's Avatar
Generally when your sprocket or chain is worn it will jump teeth under accelleration, not braking or letting off the gas. If they have not been changed it will probably be a good idea to go ahead and do it though.
Have you checked the slack in your chain? It might be a loose chain causing it.
Old Jul 13, 2012 | 01:15 PM
geoman's Avatar
Also, when replacing the chain invest in a good quality chain, not one of those cheap ones. You get what you pay for there. If that chain breaks it is common for the chain to get bunched up against the case and snap off the mounts for the case saver and/or knock a hole in the case itself.
Old Jul 13, 2012 | 01:30 PM
Webb700's Avatar
The chain is tight and the teeth don't look rounded. Could it be a missing tooth?
Old Jul 16, 2012 | 09:00 AM
geoman's Avatar
You would see it if it was missing a tooth. The noise you may be hearing could also be the chain slapping the top of the chain guide which is normal.
Firefighter400
Oct 8, 2022 06:38 PM
suzukiquadrunner1987
Aug 9, 2015 08:45 PM
Zach509
Sport Quads
Aug 3, 2015 02:44 PM
Dirtbikemike1
Technical and How-To Articles
10
Jul 12, 2015 07:22 PM
Dirtbikemike1
Jul 9, 2015 01:27 AM
