my scram blown?
Old Aug 6, 2012 | 08:30 PM
6jeff6's Avatar
Default my scram blown?
1995 Polaris scrambler 400 4x4 with less then year old rebuild..
Son was riding it and all of a sudden making a ton of lower end noise and he shut it down.
Pulled her home and it takes a lot of fuel to start and just sounds like lower end noise. Pulled clutch cover and when I pulled cover off a nut with a stud(threaded) fell from just above the cover. It came from bottom of jug(one of 4 around it)
Now am I in for a full rebuild or would lower end leak make that much of an issue?
Old Aug 6, 2012 | 09:22 PM
Air leak from the cylinder can cause it to run lean and possibly damage crank bearings,rod bearing,piston,etc. Air leaks alter the fuel,oil,air mixture ratio to where it's too lean and will run very hot. Sounds like you need to tear it down. OPT
Old Aug 7, 2012 | 02:43 AM
Forgot also,if you just did a top end only a year ago and not a full engine rebuild,it could just be the bottom end is worn and needs to be rebuilt and you could possibly save the piston and rings?. One reason I never wanted to do just a top end on older 2 strokes. OPT
Old Aug 7, 2012 | 04:41 AM
6jeff6's Avatar
Ya I was going cheap thank you for the response I will start tearing it out Sunday.
Old Aug 12, 2012 | 03:13 PM
6jeff6's Avatar
One bolt that holds jug down was broke off other side held but jug is actually cracked!
How expensive are jugs?!
Old Aug 12, 2012 | 06:45 PM
Check Ebay,BUT beware of fully bored out/worn out cylinder liners. If you can't find a good used one you can have it resleeved(if the liner is all that's cracked) at places like Lancort,etc.Last I had one done was a couple years ago(about $200-$225 if I remember correctly?) OPT
Old Aug 13, 2012 | 11:17 AM
6jeff6's Avatar
Tried to upload a pic but will not go into my files with Droid. If I get a chance I'll post on somewhere else and move it here but jug is shot big time crack around studs on bottom of jug.
Appreciate the info again
Old Aug 14, 2012 | 10:31 PM
Jmuddin284's Avatar
Rick Ritter of Ritter Cycle racing is who you need to get a hold of.... I had him do a bunch of stuff to my 400 trailblazer and other than the recomended jetting I am ABSOLUTELY happy with what I got from him.... Just google or bing Ritter cycle racing and he'll get you what you need 100%
Old Aug 15, 2012 | 06:37 AM
6jeff6's Avatar
Thanks
bmxatv10
Oct 14, 2022 06:23 PM
fd24
Jan 16, 2019 08:59 AM
kodiacrunner
Oct 4, 2015 11:52 AM
Nosniborpapa
Sep 19, 2015 07:07 PM
jsmit116
Sep 18, 2015 10:34 PM
