Polaris Cyklone 250cc "87
Old Aug 7, 2012 | 07:22 PM
Iceland's Avatar
Default Polaris Cyklone 250cc "87
Hello
I have just bougt polaris cyklone 2 stroke 250cc 1987 and I do not now how I mixed the fuel. I have heard 1:40 and 1:25 and other.
I hope you under stand what i´am writing because I´m not from USA I´m from Iceland.
With thanks
Old Aug 7, 2012 | 07:44 PM
mrtwostroke's Avatar
is there not an oil tank for injection. In front of the headlight.
If you are premixing 40 to 1 is normal for these.
Old Aug 14, 2012 | 04:29 PM
Iceland's Avatar
Yes there is a tank for the oil but he have been disconectid from the carbutor.
Old Aug 14, 2012 | 04:47 PM
Oil line should be from the oil pump to the cylinder base inlet nozzle not the carb. Make sure this inlet is blocked either with a small plug, or a small hose with a plug,etc to keep from sucking air. Then premix as mentioned 40-1 ratio. OPT
Old Aug 15, 2012 | 06:07 AM
Iceland's Avatar
Thanks for that. Do you no wher I can find the manual and part list.
Old Aug 15, 2012 | 01:38 PM
Hard to find a manual on the early models,but you can look here under your model for parts that are available,updated part numbers, plus NLA numbers which are quite a few! http://parts.polarisind.com/Browse/Browse.asp Good luck on the Cyclone. OPT
Cole Hadden
Jun 15, 2025 09:05 AM
Ramman1
Aug 11, 2022 01:53 PM
NoJoke
Aug 9, 2015 12:39 PM
Polaris Side by Sides
Jul 30, 2015 12:14 PM
Ashley S
Jul 30, 2015 08:38 AM
