85 Honda fourtrax
Old Sep 3, 2012 | 10:01 PM
Ktmrider1234's Avatar
Talking 85 Honda fourtrax
I have an 85 Honda fourtrax I have recently cleaned the carberater to do that I had to take off the gas tank and the breather tube that runs from the front of the four wheller to the breather box and of coarse the carberater. And now the four wheeler will start but runs wide open and will not stop unless you turn it off. I have adjusted the idle screw and that didnt change a thing. I'm pretty mechanically inclined but I might need some help on this one guys any suggestions. Any help is greatly appreciated!
Old Sep 3, 2012 | 10:51 PM
MIsuzukilt230s's Avatar
Welcome to the forums! It sounds to me like you may have put the slide in backwards. I've done it before and a simple 180 degree turn and I was back in business. Take a look and let us know.
Old Sep 3, 2012 | 11:17 PM
When I cleaned the carburetor I did not remove the slide but thanks I'll still try it any other suggestions again all are greatly appreciated
Old Sep 3, 2012 | 11:24 PM
So what you're saying is you didn't remove the throttle cable from the carb when you cleaned it? If that's the case then it sounds like a problem with the cable not routed correctly or is just binding up. Make sure the "carb end" of the cable is seated in the cap on top of the carb correctly.
Old Sep 21, 2012 | 06:29 AM
atvMANIAC666's Avatar
yo, ive had thhis problem, it eneded up being my choke cable, if not i can walk you through fixing it in 20 minutes over the phone. let me know, i have two ive completelty rebuit.
wendal
May 9, 2024 09:29 PM
wendal
Oct 31, 2017 03:31 AM
wendal
Sep 15, 2015 01:50 PM
Steeldon
Sep 8, 2015 10:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
