help needed for a stock hawkeye exhaust
Old Sep 25, 2012 | 08:36 AM
polarisnewbie's Avatar
Default help needed for a stock hawkeye exhaust
I just bought a used 2007 polaris hawkeye and the previous owner installed an aftermarket muffler, which doesn't fit right so it leaks and is way too loud..so I ordered a stock muffler from polaris...the last owner had to jimmy a few things to mount the aftermarket muffler and has removed the original mount for the stock muffler...I am having problems finding an original stock mount...could anyone either give me the part # for the mount or post a pic or diagram of a stock muffler mounted,so I could at least have a mount fabricated?Any help would be greatly appreciated!
Old Sep 25, 2012 | 10:55 AM
Welcome!Look here under your model and you should find what you need.Browse OPT
Old Sep 25, 2012 | 11:04 AM
Thanks for the reply!!I am guessing there are no mounting brackets..I have checked this site and it only shows the nuts and bolts...guess the muffler attaches directly to the frame..I have tried to mount it this way,but the muffler ends up short of reaching the header pipe enough to create a tight seal, with the seal ring in there...maybe the previous owner bent the header pipe to fit the aftermarket muffler...I have also called some polaris dealers and they seem a bit baffled...oh well, guess I will have to fabricate something in order to make it work!again thank you!
Old Sep 25, 2012 | 11:32 AM
Yes the muffler mounts are part of the frame and the bolts go through these to the slots on the muffler. Sounds like a little welding may be needed. OPT
Old Sep 25, 2012 | 03:56 PM
thanks for your help OPT!!Gonna have to fabricate something and by the sounds get some welding involved.
Hankey Pankey
26
Oct 18, 2020 03:50 PM
jrooker6
Ask the Editor
11
Apr 21, 2016 07:35 PM
VRRRRT
Jun 27, 2015 09:38 AM
Rtgjje5
Jun 16, 2015 08:23 AM
