Need help LOST!!!!
Old Sep 28, 2012 | 06:40 PM
brianza3's Avatar
Default Need help LOST!!!!
Need help. My boys 2006 predator 50 is having starting problems only with the electric start. We replaced the battery, stator, and the starter. The starter was a cheap 40.00 china starter. It wants to crank over but cranks slow. The old starter and new starter is doing the same slow cranking, It will kick over with no problem at all by kick start, but when using the starter sometimes it works but turns real slow. Starter gets real hot and even smoked a little the last try. Please help. I give up. Maybe the brand new china starter is a bad one??? I hear the relay in rear working but hard to turn over. Battery is new.
Will the relay make the starter turn slow
Old Sep 28, 2012 | 08:18 PM
Please don't double post in the expert section and in the normal thread area on the same subject,gets confusing Hopefully have some things for you to check out in your other post. OPT
lonerider856
Oct 13, 2023 03:45 PM
Nosniborpapa
Sep 19, 2015 07:07 PM
bvolks
Sep 13, 2015 12:57 PM
bigbear350quad
Sep 11, 2015 12:40 PM
MeadowlarkFarm
Sep 9, 2015 03:08 AM
