05 400ex won't start!
Old Oct 8, 2012 | 03:36 PM
codyfrey27's Avatar
Default 05 400ex won't start!
My 05 TRX400EX won't start, it turns over but will not start. it makes a fairly loud clicking noise when turning over which seems to be the valves or timing chain. What should I look for/ check? Can incorrect valve or timing adjustment cause this? Any help would be greatly appreciated!
Old Oct 9, 2012 | 03:28 PM
Fullblast's Avatar
Incorrect valve adjustments or timing can cause this, however, it could easily be something else. Have you checked the spark plug and ignition coil? It also could be a dirty carburetor not letting fuel through. The timing chain could have slipped if the it has never been replaced, especially if the atv has a lot of hours on it.
Old Oct 9, 2012 | 09:15 PM
Knust's Avatar
Does 400ex have a starter clutch. engine might not be turning over at all. I am not familiar with that engine but most have a 1 way bearing for starting. they make a lot of noise when they go out.
DTroyer01
Jul 3, 2015 07:34 AM
Bm400ex
Jun 22, 2015 09:16 AM
1000gade
May 27, 2015 12:37 PM
2punksdad
May 23, 2000 01:46 AM
jbertch
Nov 6, 1999 07:07 PM
