97 Timberwolf ignition switch info, PLEASE!
Old Oct 11, 2012 | 06:55 AM
Justin Gordon's Avatar
Default 97 Timberwolf ignition switch info, PLEASE!
Ok i got this 97 timberwolf for a hundred buck, the rear diff is trash of course, but other than that not a bad looking atv. It has so much compression that i cant pull start it hard enuff to get it to fire, it takes a big man. The ignition switch is missing, the plug is still there all i need to do is buy a new switch on ebay, my question is, is there anyway to start the bike without the switch there, or is the bike not gonna get any fire? I figured with the switch gona it would be like the atv is turned off. Is there anywya i could jump two of the port in the plug and get it to start, i just want to hear it run. It will turn over fine if i jump the solinoid, but it seems like the kill switch is off , if ya know what i mean. I just a need a little info, you guys are great
Old Oct 13, 2012 | 07:59 PM
knepa22's Avatar
Compression? Does the pull start have alot of 'resistance'? For safety precautions i wouldn't 'hot wire' the starter switch until you recieve your new one. For a $100 the quad is a steal, i wouldn't mess with anything electrically and risk creating unwanted issues.
Old Oct 13, 2012 | 09:19 PM
Raptor450's Avatar
The bike is not gonna fire with the key switch off. No one is allowed to tell you how to hot wire a key switch on here so you'll just have to buy a new one off ebay. You can usually get one for about $35. As for the compression, there may be a compression relief lever around the top front of the head. If so flip that up before you pull it and that will make it much easire to pull
skinnyr6
Aug 25, 2023 02:18 AM
jeepwheelin02
1) Engine problems..
Jul 18, 2020 06:42 PM
Hatrackr
Aug 11, 2015 09:03 PM
WILLLANE8302
Aug 7, 2015 08:24 AM
ScopeZ_
Jul 28, 2015 01:44 AM
