1998 Xplorer 300 4x4 starter removal
Old Oct 15, 2012 | 10:43 AM
Fulmer's Avatar
Default 1998 Xplorer 300 4x4 starter removal
I recently removed the starter from my daughters quad and thought I would post as it was a pain and I could not find info on removal. Disconnect battery. I removed the clutch cover since the inner seal on the clutch cover was cracked and needed replaced. Removed drive clutch using a 3/4" diameter, 6" long, fine thread bolt. Driven clutch was much more difficult since it would not simply slide off the splines. Could not find anywhere a 1" diameter, 2" long, #12 fine thread bolt to use as a puller. Tried a trailer ball hitch and several 1" fine thread bolts I had around, but none would threadin. I wound up buying the puller off Ebay for $19. When receiver the puller was too long and I could not start the threads. I had to cut 1/2" off to thread. Removed few bolts holding inner plastic clutch cover.
You now have easy access to the starter. Removed line from battery. Remove skid plate. Remove 4 bolts on bracket mounted to starter and engine. Remove fly wheel cover, bottom bolt is a pain do break lever arm. Remove the 4 bolts on this bracket. Good Luck
Old Oct 15, 2012 | 11:16 AM
You actually did it the easiest way,but like you said it's still a lot of work replacing starters on the 250,300 and 400 atvs. I always pulled the clutches and backing plate to gain access to the starter bracket bolts also. I tried years ago standing the machines on their tail ends,removing the bash plates and fighting to get the back starter bracket bolt out! Just a big pain especially if you have big hands. Congats on the job,plus your post just might convince others this is the best way rather than fighting it. OPT
ghost civic
Jan 15, 2020 07:43 AM
ghost civic
Jul 27, 2015 03:15 AM
Desimation2k8
Jul 17, 2015 12:37 AM
ghost civic
Jul 15, 2015 10:48 PM
honda71
Jul 12, 2015 05:56 AM
