2003 polaris magnum 330
Old Oct 15, 2012 | 12:26 PM
mobilemech's Avatar
Default 2003 polaris magnum 330
looking at the service manual i don't see the rectifier / regulator location or it described in the schematic. Is it the CDI box and is it under the fuel tank by the ECU
Old Oct 15, 2012 | 01:58 PM
You had one of the early ecm modules that controlled the fan,charging,etc. Look here on your model under "electrical" .Browse Wasn't under the general recall of ecm modules that I'm aware of,but it's still Chinese! Can't remember If I replaced any or not? Huge ATV Recall by Polaris - Sportsman and Scrambler OPT
Old Oct 15, 2012 | 11:30 PM
mobilemech's Avatar
OPT, thank you for the info, are there any tests that can be done?
Old Oct 16, 2012 | 05:20 AM
The only test on the module was with a tester that Polaris sent when we had the recalls,BUT they wanted it back. Worked in the same way a battery load tester works,it put a load on the ecm and showed if it was good or bad. If you're not charging 14-14.5 volts back to the battery, the ecm module needs to be replaced as this was one of it's primary functions. Plus if you're not sure about the battery,just have it load tested at any auto store. OPT
Old Oct 16, 2012 | 09:16 AM
mobilemech's Avatar
I am sure the battery is toast, but i do have a load tester and will confirm that it is bad. them with a known good battery I'll see what the voltage at the battery is while running, before jumping into just throwing parts at it.
OPT, thanks for the help and info.
Jmuddin284
Jan 19, 2026 07:16 AM
slowgsxr97
Mar 18, 2022 03:40 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
jettman
Jul 6, 2015 12:16 PM
