Will rims and tires off a newer kodiak fit old?
Old Oct 22, 2012 | 03:58 PM
BrianJ's Avatar
Default Will rims and tires off a newer kodiak fit old?
I have a 1995 Kodiak and keep seeing sets of take off rim and tires online. Will they bolt right up to mine?
I found a reference online that shows the bolt pattern is the same but I have a solid rear axle and most things newer have independent.
Thanks
Old Oct 22, 2012 | 05:39 PM
TLC's Avatar
TLC
As long as the bolt pattern and off set is the same they will work. Here is a good chart
ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
Old Oct 23, 2012 | 01:16 PM
BrianJ's Avatar
Thanks for the chart. Reading through that it looks like to me like ATVs with IRS will not interchange rear wheels with solid rear axle ATVs. Can anyone confirm or deny that?
Taken from above website:
* Designates same wheels and offsets for front and rear. These machines use the same wheel on front and back. These machines typically have independent rear suspension. ITP replacements for these machines are 4/110 Bolt pattern with a 5+2 offset. Sometimes this is referred to as "4 front wheels" since the front wheels are also used as rear wheels on independent suspension machines.
JackTheKing
Sport Quads
Nov 4, 2019 06:06 AM
89Lt250r
Sep 7, 2015 07:53 PM
black_thunder
Sep 7, 2015 01:24 AM
Logan Collins
Sep 5, 2015 08:03 PM
TLC
Sep 5, 2015 12:49 PM
