What's missing?
Old Oct 26, 2012 | 05:34 PM
kawasakicowboy's Avatar
Default What's missing?
My throttle cable broke this week and I ordered a new one. The problem I'm having is that when I took the throttle body apart down in the woods to hand throttle it back home ,it looks like I lost the part that holds the cable in place. Does anyone have an alternative fix ,or a name for it with a possible part # . That would be great since it is harder than hell to find it on Polaris website. It's a 2006 Polaris ranger 700, Thanx
Old Oct 26, 2012 | 05:46 PM
Don't know if you're talking about the foot pedal "nutsert" as it's called or something else? You can look here under your model Ranger under "throttle " and see if this helps locate the part you're missing. Browse If it's a little brass cable lock(#3130543) in the throttle body wheel that turns the butter fly,it doesn't show in the break down,but is shown on other machines on carb parts? OPT
Old Oct 26, 2012 | 06:32 PM
Default You sure know ur stuff!
Thank you ,it must be the brass part,cause th cable is to small to fit in the butterfly that is in the plastic cover in the throttle body.
Old Oct 26, 2012 | 06:52 PM
Default Holy crap!
That little tiny part cost $13.00
Old Oct 26, 2012 | 07:27 PM
YEA,I know!. You might check at a shop nearby (if you have one close) and see if they have some old BST carbs or throttle bodies laying around that you could get used parts from at a cheap price . I had stacks of old carbs just for this purpose when guys lost parts. Good luck OPT
95wolv
Sep 27, 2024 12:00 PM
cswiger
Polaris Side by Sides
12
Oct 5, 2015 03:34 PM
panicmanic
Sep 28, 2015 12:59 PM
tysonbully
Sep 28, 2015 02:30 AM
Ridgebackguy86
Sep 19, 2015 12:48 PM
