ds650 lockbolt question
Old Nov 11, 2012 | 10:46 PM
300ridin's Avatar
Default ds650 lockbolt question
I think im having some timing issues on my ds650, so i made a lock bolt but im not seeing where the slot is on the crank that this lock bolt goes into. Does the magneto need to be in a certain spot when i get the motor to TBC?
-- i have a owners manual and it doesn't tell you how to do it.
Old Nov 12, 2012 | 09:52 AM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
The slot is at TDC. If you shine a flashlight in to the hole while you rotate the crank you will see it. Be sure to remove one of your spark plugs to aid in turning the crank with an allen wrench.
Old Nov 12, 2012 | 11:31 AM
300ridin's Avatar
yeah i found a nice guide on it after i posted a thread, when atv starts it is not getting enough gas or air, i tinkered with the air screw and it did not run any different. Ive cleaned the carb 3 times...what should i try next?
Old Nov 13, 2012 | 03:15 AM
justme23005's Avatar
Take a close look at the diaphram on the top of the carburetor
Old Nov 13, 2012 | 02:34 PM
300ridin's Avatar
ive checked it, it looked fine no rips or anything the atv is extremely hard to start hot or cold, have to choke it and hold the gas wide open and it will eventually start, it will hit try to start but wont happen sometimes i will get lucky and it will start on the 3 or 4th crank but usually takes about 15.
Old Nov 13, 2012 | 07:56 PM
aceisback's Avatar
Military Rider
I would check the valve gaps. Sounds like you may be tight.
Old Nov 14, 2012 | 11:38 AM
300ridin's Avatar
all the valves are good except one intake valve is off my a thousandth that im replacing later today
Old Jan 1, 2013 | 03:15 PM
infantryvet's Avatar
1 intake being off can do it.If its tight then its leaking enough compression to keep from starting.prolly backfiring into carb as well.i know old post just in case people are snooping around the forum with questions..lol
Alex G.
Sep 11, 2017 11:38 PM
EIF
Apr 20, 2017 07:15 PM
Ahtatu
Sep 28, 2015 12:14 PM
2many2ride
Sep 27, 2015 04:35 AM
Quadzilla Heritage
Sep 25, 2015 01:39 PM
