07 polaris hawkey starting problem
Old Nov 13, 2012 | 11:59 AM
tcr03's Avatar
Default 07 polaris hawkey starting problem
i run and auto repair shop and had a customer bring in his atv with intermittent cranking issues. we diagnosed it to be starter solenoid. i put one and and it started up fine. it ran for a few minutes and then stopped. now all it does is crank and no start. its not getting spark. im thinking that the cdi box is the problem, but id like to know what inputs the box gets so i can eliminate the parts that send signal to the cdi box.
thanks in advance
matt
Old Nov 13, 2012 | 12:12 PM
Welcome! The Cdi gets its signal from the stator assy. You might see if this place still offers manuals you can down load that you can do a resistance test on the stator.PartShark.com - Motorcycle Parts, ATV Parts, UTV Parts, PWC Parts, Powersports Apparel, Motorcycle Accessories for OEM and Aftermarket. ALSO you might check the parts breakdown under "electrical" on your model as it does have fuses that may need to be checked out.http://parts.polarisind.com/Browse/Browse.asp OPT
Old Jul 1, 2013 | 11:35 PM
fordfanatic69's Avatar
I'm having problems cranking too. I get spark but no start. I'm trying to get any idea of what I need to check.
Old Jul 2, 2013 | 06:52 AM
You have to have compression, air, fuel and spark. First thing I'd check is fuel flow and clean the carb and keep some fuel stabilizer in it. Probably wouldn't hurt to check the valves.
TJM
Jun 11, 2015 01:28 PM
Steven Bandemer
Jun 9, 2015 08:50 PM
generalpops
Jun 5, 2015 08:23 PM
garyt1975
Jun 5, 2015 08:53 AM
1000gade
May 27, 2015 12:37 PM
