Yet another question on Rzr/sportsman wheel fitment..
Old Nov 13, 2012 | 04:17 PM
Mike-3137's Avatar
Default Yet another question on Rzr/sportsman wheel fitment..
I know this has been hashed and rehashed with similar bikes but different model years than mine. at least on all the threads I read..so I'll dare to ask it with my exact situation..
I am being offered a really good deal on a set of 4 brand new 27" itp tires and stock 2011 RZR aluminum 2011 12" rims....Will they likely fit my 2006 sportsman 700, will they need 1" spacers in rear or all the way around..or should I forget the whole thing?
Thanks for any help!
Old Nov 13, 2012 | 05:05 PM
TLC's Avatar
TLC
They both have 4/156 bolt batterns like most Polaris ATVs. The rear tires will not need spacers there just to much room to spare back there even if you go wider.
How wide are the new tires? ATV Tire and Wheel Application Chart : ATV Tires Free Shipping : ATV Wheels : Mud-Throwers.com
Old Nov 13, 2012 | 05:26 PM
Mike-3137's Avatar
not sure just yet..just been told they would fit but would be noticeably inset on the rear..and will need 1" spacers plus new wheel studs and lugs...probably need the studs/lugs anyway for any aluminum wheels i'd bet.
Old Nov 15, 2012 | 08:09 PM
bad87gn's Avatar
They won't be inset and you won't need spacers. Longer wheel studs may be necessary if yours came with steel wheels, and you should have the closed end lug nuts for the alum wheels
Old Dec 12, 2012 | 12:05 AM
Mike-3137's Avatar
Here's a followup in case someone wants to do this...You DO need 1" spacers front and rear. The rear tires were contacting the sway bar, and the front tires were rubbing the boots on tie rods. In fact I would probably go 1.5 on the rear just to have the track the same front to rear, as the front width is a tad wider than the rear now.
The ideal setup would be 1" spacer/adapter on the rear and use a flat 1/2" spacer on the front along with longer studs to make it just right, but I wasnt able to find a 156mm flat spacer, and didnt feel like spending the time to make a pair for the front.
Size:  83.7 KBName:  2012-11-29213437.jpg
Old Dec 13, 2012 | 02:30 PM
bobx2's Avatar
You need to study up a little before you spout out bad advise like that. Not cool to try to make it sound like you know what you're talking about when actually, you have no clue.
Kyle5050
Dec 13, 2019 04:25 AM
Bergmann
Aug 13, 2015 03:51 PM
toonces
Aug 5, 2015 05:55 PM
Jul 21, 2015 03:03 PM
yambam13
Jul 4, 2015 01:49 PM
