can any one help need parts for this quad
i was recently given a quad from a friend and have no clue what year make or model it is the motor is coolent cooled and says 196cm numbers on it are jl163ml/050c0090 the name on the motor is Boreem there is allso a plate riveted batween the A arms with 205-bawa-03 and behind the A arm on the frame is Laazomlo652c00048 im in need of a rear axle shaft for it and bolt kit for the rear axle and have no clue what size and were to get it can any one help me i contacted bms motorsports but they have no clue from what i can tell all they told me is it was discontinued in 07 like that helps me get the parts and scemadics i need
sounds like a 2005 BMS 200cc quad. yep, it's a boreem motorsports quad.
try these folks, see if their quad matches up with yours. i'm unsure cause you didn't post a pic of your quad.
BMS ATVs Parts
Bms ATV Parts
don't know much about the motopartscenter website, i've never dealt with them. good luck.
BMS ATVs Parts
Bms ATV Parts
BMS ATVs Parts
Bms ATV Parts
BMS ATVs Parts
Bms ATV Parts
let me do some diggin on this one. a lot of the chinese quads actually have multiple parts that interchange from one brand to another. yeah, roketa parts can fit hibird, redcat can fit kazuma, etc....a lot of peripheral parts will definitely interchange as a factory will supply several manufacturers the same part. kind of like GMC will fit chevy, oldsmobile, pontiac, etc.....but you're right, 200cc water cooled quad that's a 2005 model.
any luck on finding that stuff out for me
Frisky2050
Apr 9, 2020 11:19 AM
