2003 ds 650 baja starter/solenoid issue
Old Nov 24, 2012 | 12:19 AM
300ridin's Avatar
Default 2003 ds 650 baja starter/solenoid issue
i hit the start button i get several clicks from the solenoid and i can feel the starter trying to turn, i took the starter out and hooked it to the battery spins good that way.if i cross the solenoid over it doesnt do anything at all, ive checked most connections and cleaned them, before all this happened it worked fine ...then i went to turn the key on no power finally found the main fuse had blown replaced now it does the click thing... no clue what blowed it
Old Nov 24, 2012 | 11:02 PM
300ridin's Avatar
changed the battery, did not help.
Old Nov 30, 2012 | 11:02 PM
300ridin's Avatar
Figured out the problem, when i put the side case on i had a washer on the outside of the starter gear and it was causing the sidecase to push the gear against the crankcase thus locking it completely up...
slowgsxr97
Mar 18, 2022 03:40 AM
velcro7279
Aug 24, 2015 01:15 PM
bpegram84
Jul 22, 2015 08:15 AM
MATT BOOTH
Technical and How-To Articles
Jul 20, 2015 07:38 PM
MATT BOOTH
Utility ATVs
Jul 20, 2015 05:55 PM
