DIY: Rear Shock Bushing Replacement $1
Old Dec 16, 2012 | 12:24 PM
eightyhd's Avatar
Default DIY: Rear Shock Bushing Replacement $1
Ok, so i was lifting my 01 Sportsman 500HO and saw the bushings were REALLY bad!
I was lucky enough to scrounge around and find some hose, so i said screw it..
Better than paying the $120 for a new bushing kit.
And it worked out so well!! And the ride is definitely better than it was before.
Good luck all!
Youll need:
1ft 5/8 Hose (Get it at your local auto parts store)
Mallet
Razor
Lube
NOTE:
The upper Pin and Lower pin may look alike, but different sizes
Be sure you only do one side at a time.
1. Insert Metal Pin into hose
2. Cut so it has a bevel (Doesnt have to be perfect)
3. Lube the inside
4. Thread it
5. Mallet
6. Trim the other side
Beveling
Mallet
Trimming:
NOT BAD FOR LESS THAN A $1/FOOT!
Old Dec 16, 2012 | 12:41 PM
Good DIY method. If these don't hold up you can try this place. Had some customers use these harder than oem replacements and had good luck with em .http://www.energysuspension.com/univ...-bushings.html
OPT
Old Dec 16, 2012 | 12:43 PM
eightyhd's Avatar
i didnt want to spend more than a $1, LOL!
But hopefully this will be useful for someone that doesnt have time to wait or $$$ issues.
1966F100
Jul 12, 2015 03:08 AM
rcappie4
Jul 10, 2015 04:54 PM
Rider252
Jul 6, 2015 03:37 PM
jettman
Jul 6, 2015 12:16 PM
Jkfx400P
Jul 6, 2015 10:04 AM
