400EX full pipe shootout FINALLY!!!
The latest issue of ATV Sport has a shoot-out of a bunch of pipes for the 400EX! Mostly full pipes but they tested some slip on silencers too. Over 16 different pipes were tested on a new 400EX with jetting specified by the pipe manufacturer. Testing was done with a DynoJet Dyno and a Stalker radar gun used in conjunction with acceleration testing software.
Looks like the Curtis Sparks is making the most peak hp but WhiteBro.s' ProMeg is very close behind and then the DMC. Check it out at ATVNews.com
thanks alot taht was verry helpful.
I am reconsidering the Pro circuit and leaning twords the White Bro's. Is everyone satisfied with it? Does it work good on modded engines?
thanks
thanks
It looks like thay used a cdi with the Sparks set up but not with the White bros.
I've been told that the stock head pipes flow fine for a stock 400EX. I will have to look back at the DW article and compare the numbers.
Booboo
Booboo
