charging issues
Old Jan 12, 2013 | 04:08 PM
Steven Furletti's Avatar
Default charging issues
I have a 2004 predator 500... I have the battery on a maintainer.. I then go out to ride and eventually the battery dies... I have replaced the regulator and checked charging by revving motor and watch voltage go up.. seems to me it is ok but still killing batteries to the point at which I cannot recharge them and have to get a new one.. any ideas?
Old Jan 12, 2013 | 04:59 PM
With the new reg/rectifier the charging rate should be between 13.5 to 14.5 volts,but this doesn't mean the battery is capable of holding the charge if it has a dead,shorted out cell. Make sure the battery connections are tight also,but I'd have the battery load tested. This will tell real quick if it needs to be replaced. I've even had new batteries that were bad straight out of the box. OPT
COFatboy
May 2, 2020 12:06 AM
cody500ho
14
Aug 14, 2015 05:03 PM
Ronbo6270
Aug 6, 2015 11:54 PM
200es
Jul 19, 2015 04:50 PM
bzdok1234
Utility ATVs
Jul 3, 2015 05:32 PM
