01 trailblazer ?
Old Feb 9, 2013 | 04:15 PM
Tattered_n_torn's Avatar
Default 01 trailblazer ?
Need to pull the trans looks like you have to pull the swing arm anyone know the size of socket you need for that bolt I would prefer to only make one run to the store for the correct size socket
Old Feb 9, 2013 | 04:46 PM
Swing arm doesn't have to be removed to pull the transmission. You may have to loosen the swing arm bolts a little if I remember correctly "IF" they protrude into the transmission case.(I don't think they do) Also can't remember if this model has the combo drain/transmission support bolt. If it does,the lock nut had to be loosen and the bolt turned in to be able get the drain plug out,then to get the transmission out. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
OPT
neo27ny
May 14, 2018 12:19 PM
chewy78
Sep 8, 2015 10:37 AM
tmboy
Technical and How-To Articles
Sep 1, 2015 09:20 AM
suzukiquadrunner1987
Aug 6, 2015 03:59 PM
shewshew989
Jul 14, 2015 03:09 AM
