CAN-AM (BRP) Ask an Expert! An area where experts in their field will answer Non-General or Non-Basic questions about your CAN-AM (BRP) ATV. ASK ALL GENERAL QUESTIONS OR BASIC QUESTIONS IN THE CAN-AM (BRP) SECTION. Basic or General questions posted in a expert section will be moved!
MrHorsepower and other experts will answer your questions as they have time.
2004 ds650 baja x rough starting
Old Feb 13, 2013 | 08:56 AM
bird720's Avatar
Default 2004 ds650 baja x rough starting
aight i have had this problem befor and it was the one way bearing or starter sprag on the flywheel. i replaced the bearing only. that fixed it for a little while. now its doing the same thing. making terrible noises when trying to start it up. so this time i replaced the bearing, hub, and gear, everthing that one way bearing touches. its still making the same grinding, scratching, knocking. noise while starting. as far as i know the motor is fine. ran perfect last time i rode it, just rough to start it.
anybody have any ideas about whats going on with it?
Old Feb 13, 2013 | 04:01 PM
aceisback's Avatar
Military Rider
My hobbies are NASCAR, Rockin' in the Free World, and riding my Sand Pigs at every available opportunity.
These Rotax motors create a lot of compression and when they don't start the "kick back" is pretty loud and seems to spook some folks in to thinking something has broken. It may just be the flywheel spinning back forward. They are a noisy motor but very reliable.
Are you sure it's not just a noise that you're not used to with other makes?
Old Feb 14, 2013 | 06:53 AM
bird720's Avatar
well this bike has never done it befor other than now. i can take one plug out and still hear the noise..
Old Feb 16, 2013 | 10:23 AM
justme23005's Avatar
Sounds like the one way bearing is going bad again.
Jun 15, 2015 11:22 PM
JackTheKing
Jun 14, 2015 03:04 PM
Jun 8, 2015 06:45 PM
1000gade
May 27, 2015 12:37 PM
