you wanna hop up your 400ex
Old Mar 24, 2001 | 11:44 AM
TrX465's Avatar
the easiest mods you can do if you have a stock head pipe you can take off your head pipes and grind down the welds this will help with the flow.
get for $15 you can get advanced timing pin and it will also make an effect. Maybe put a slip on muffler and a high rev cdi box and you should have a nice little set up...
Old Mar 24, 2001 | 01:38 PM
max400ex's Avatar
thanks thats some good advice
Old Mar 24, 2001 | 05:34 PM
wheeliedude's Avatar
What's an advanced timing pin?
Old Mar 24, 2001 | 05:53 PM
LDJ's Avatar
LDJ
I would not recommend the step key ignition, I have had 4 of them shear on me. Do not touch your flywheel.
Old Mar 24, 2001 | 06:55 PM
adamsmith's Avatar
Sparks says not to use the key on 440s or bigger cause they already run hot, and the key makes them run too hot.
Adam Smith
99 400EX
Old Mar 26, 2001 | 12:19 AM
TrX465's Avatar
i got a 465kit with a lightned flywheel, 6 degree advanced timing, titanium valves ,Custom race cam, 3-way valve job, port polished, hot rod (rod),customed made cam chain, Lrd big bore exhaust, trued and welded ,had the crank shaved down , alcohol for my 39 fcr carb ,i got an 8 inch swing arm, chromed frame, polished head,case custom design paint on plastic.Never once have i sheared anything.
((((((AS THE T-REX EATS THE RAPTOR))))))
Old Mar 26, 2001 | 06:50 PM
MX265X's Avatar
but you wont run hot either because you are running alcohol and your timing needs to be advanced to run it! about the searng i dunno!
Old Mar 27, 2001 | 11:30 PM
2001REDTRX's Avatar
Unless you have a built motor the timing advance does you no good, your motor cant handle it. ANd as far as the header mod goes, your increase is not even worth the time you spend filing them down. The CDI and Slip on however will have a little bit of an increase over stock.
Old Mar 28, 2001 | 09:22 PM
Michaud68's Avatar
Dont forget cam timing you can slot your cam sprocket and degree the cam for some extra ponies.
badgerboy1
Sep 26, 2017 06:11 PM
XxS0ccerstarxX
Sep 24, 2015 11:53 PM
XxS0ccerstarxX
Sep 24, 2015 05:38 PM
XxS0ccerstarxX
Sep 24, 2015 02:02 PM
XxS0ccerstarxX
Sep 22, 2015 02:40 PM
