Question about 400ex
Old Feb 26, 2013 | 04:14 PM
fretfulnight6758's Avatar
Default Question about 400ex
Well this guy has a 400ex for 1300 talked him down to 900$ cause the rings in it are not that good... He has a set of rings but he doesn't no how to put them in.. Im going to buy it and then just send it to my friends and his did will do it for me.... For $100. Better then taking it down to a Shop for 300$ in labor.. Anyways what will it do if i run it with bad rings... He said it smokes blue when first started but it stops when running.... Will it not harm it that much but just eat my oil... and lose some power
Old Feb 26, 2013 | 05:58 PM
All these views no comment lol.. Im just asking.. what could happen if i keep runing a bike with bad piston rings.... Would it just burn my oil faster or could i blow it up?
Old Feb 26, 2013 | 06:19 PM
jgar's Avatar
It will burn more oil the more you use it. Blow up? Probably not, but you never know.
You might find upon tearing down the top end that it needs to be bored. If you get lucky it will need a hone and rings. Odds are it will need a bore and new bigger piston.
Old Feb 27, 2013 | 03:27 PM
Dam.... So i cant just replace the rings... I would have to replace the whole top end basically?
Old Feb 27, 2013 | 04:02 PM
jgar's Avatar
You might get away with just a set of ring. Or you might need to replace the piston. You wont know until its torn down.
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
wendal
Sep 15, 2015 01:50 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
