Brute force 2" receiver hitch
Old Mar 7, 2013 | 02:56 PM
Hedgehog's Avatar
Default Brute force 2" receiver hitch
Can anyone tell me who makes the best 2" receiver hitch for a 2010 bruteforce 750? I see moose, koplin & promark make them. They all look different in the way they attach. I will need a strong one because occasionally I will be moving a 16' enclosed trailer in my yard. I know it will move it because I have used a craftsman garden tractor in the past to move it. I also might mount a sander in the hitch for winter snow removal duties. Thanks in advanced.
Old Mar 7, 2013 | 04:26 PM
mudslinger2's Avatar
I haven't been stuck since the last time!
You are much braver than me if you are moving a 16ft enclosed trailer around with your quad...that is a lot of tounge weight on the quad. I use my quad to pull my 18 ft flat trailer, but use a set of wheels right under the ball to carry the weight and then hook that up to my quad.
Old Mar 7, 2013 | 04:56 PM
Airb's Avatar
Sometimes the diagrams or pictures for parts aren't the same as they are in real life. I would recommend moose because I have had good experiences with their products.
Old Mar 7, 2013 | 06:13 PM
Hedgehog's Avatar
The trailer is actually 20' total length but it is a tandem axle. Seems the extra axle helps with the tongue weight. I only move it 30' in the spring and 30' in the fall. So, only twice a year.
Old Mar 7, 2013 | 07:50 PM
beergut's Avatar
ʇsıʇɹɐ ɹǝʌolloɹ
any 2" hitch you have listed above will work- your atv will never even come close to pulling the max weight a 2" hitch is rated for- even a cheap chinese made one..
Old Mar 8, 2013 | 02:53 AM
Hedgehog's Avatar
The trailer usually only has a motorcycle in it for winter storage so it probably weighs around 3000#'s. it is only rolling on pavement. I currently move it with a craftsman riding mower. I just move it slow to keep it in control.
Old Mar 8, 2013 | 02:55 AM
Hedgehog's Avatar
I just figured I have no use for the tractor as long as the atv will pull the trailer. Other than that, the tractor was only used for sidewalk plowing but the atv now has a plow. Just wanted to consolidate and make some room in the garage. If the atv won't move the trailer, I can always keep the tractor.
Pgbama11
Jan 16, 2016 08:19 AM
Ryan Downey
Exotic and Modified Quads
Sep 29, 2015 09:31 AM
ylomnstr
Sep 22, 2015 12:19 AM
Pgbama11
Sep 10, 2015 08:20 AM
ylomnstr
Sep 4, 2015 05:02 PM
