Will 450r shocks fit on a 2012 Trx400x?
Old Mar 14, 2013 | 01:56 PM
justinx1997's Avatar
Default Will 450r shocks fit on a 2012 Trx400x?
Title says it all. Im tired of not being able to hit bigger jumps, so I want jew shocks. Obviously new ones are expensive, so i was gonna go with used 450 suspension. I would also like to know if there is any way you can make yfz450 suspension fit a 400x. Thanks in advance!
Old Mar 22, 2013 | 04:37 PM
Come on, help!
Old Mar 22, 2013 | 05:58 PM
jgar's Avatar
Trx 450r front shocks will fit. You may have to grind out a very minor amount of the upper shock mount. I removed about 1/16 from the corner of the upper mount. The rear trx 450r shock will lower the machine about 1 inch.
The yfz front shocks will fit if you cut the upper portion of the shock (thickness) to fit in the x mount. Not sure about the rear.
mark23
Oct 1, 2015 09:57 AM
cboler9
Sep 24, 2015 08:35 PM
Todd C Wadas
2) Chassis problems..
Sep 23, 2015 11:31 PM
bigred20653
Sep 19, 2015 02:11 PM
greg74
Sep 10, 2015 07:58 AM
