No Spark, Replaced Everything ???
Old Mar 15, 2013 | 11:19 PM
~Ray~'s Avatar
Default No Spark, Replaced Everything ???
125D Tao Tao
New, worked first day, next day no spark.
Replaced: CDI, Stator, Coil, Remote/Alarm, Kill Switch, Spark Plug, Regulator, Ignition.
All parts were taking off another Brand New exact model wich not only worked perfect before swapping parts but still ran perfect after putting all these parts from the non running one on it.
Any suggestions ? I'm at a loss, tried unplugging Tether & even made a wire to stuck it both ends to make sure that it is bypassed, uplugged every plug, inspected & dielect every connection
Old Mar 17, 2013 | 02:47 AM
mudmike's Avatar
Hmmm... parts that are known to be good but bike has no spark?
First thing I'd do is check the fuse (use something better than your eye) if that didn't fix it i'd start looking for a pinched wire in the kill switch circut.
Old Mar 17, 2013 | 11:12 AM
~Ray~'s Avatar
Ya even put all the parts on the (known working) one & it even still worked.
Inspected & Changed Fuse.. Without fuse it would not even turn over.
I'm gonna try removing the kill switch pin from the CDI today (Heard you can do it) Thanks that gave me a idea atleast
Old Mar 18, 2013 | 01:10 PM
~Ray~'s Avatar
OK This is where I'm at now,
Removed the kill switch wire from CDI, Fires right up so now I need to know how to eliminate wich kill switch is the problem ?
I've already replaced the Kill switch on Handlebars & Alarm System, only thing I didn't replace was Tether Cord because I could not get it off, but unplugging it should bypass it though right ?
Old Mar 18, 2013 | 02:32 PM
~Ray~'s Avatar
OK Fixed.
Not sure what it was, removed kill switch wire, plugged it back in & all works now, must have been a bad connection.
Old Mar 20, 2013 | 09:15 AM
mudmike's Avatar
glad to hear it was a simple fix
NatePerz
Jul 27, 2015 03:27 AM
ghost civic
Jul 19, 2015 10:13 AM
Unzzy66
Jul 11, 2015 10:01 PM
sublime250
1) Engine problems..
Jul 11, 2015 11:52 AM
jettman
Jul 6, 2015 12:16 PM
