2008 scrambler 500
Old Mar 27, 2013 | 03:08 PM
railbuggie's Avatar
Default 2008 scrambler 500
reverse light is on in forward and reverse, neutral light is on when its in neutral and it has full power in reverse without pushing override button. 4x4 works. electric switch in tranny is good I swapped it with one out of my 2000 scrambler and it does the same thing. I cant swap out the reverse limiter because they are not the same. Could that be the problem or maybe something else?
thanks
Sam
Old Mar 27, 2013 | 03:47 PM
If the tranny switches are the same?the part numbers show different! Did you test the switch before it was mounted by pressing the plastic levers to see if speedo registered it?? If the reverse light is still on the speedo,probable short in the harness or connector,plus the reverse limiter is built into the speedo itself on this model. It could be faulty.There is a post on this that someone did to bypass this. I'll see if I can find this unless someone else jumps in with a quick answer.
Old Mar 27, 2013 | 06:18 PM
railbuggie's Avatar
Thanks for the quick reply. The part nos are different but I swear they are the same. But this bike doesnt have a speedo. I bought it new and it never had one. do you think it could be the rev limiter under the hood?
Old Mar 27, 2013 | 07:24 PM
Sorry,thinking of a Sportsman again!Shows to have a reverse limiter module. Haven't had a problem I'm aware with this model,but entirely possible it could be faulty causing the problems. I just have to find a good test on this one.If it's like the older ones,pulling the main black wire disabled it. Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse I'll check some more and see if I can dig up some more info.Plus here's a pdf on a 2009 model(that may be the same) you can down load yourself.http://www.partshark.com/custompage3.asp?pg=polaris
Old Mar 30, 2013 | 06:38 PM
railbuggie's Avatar
got it figured out. the override switch was full of mud. it was clean on the outside. told my 18 y/o son he found a new way to french something up. ive had polarises for 20 years and that was a first.
thanks
Sam
Old Mar 30, 2013 | 09:55 PM
A lot a of times it's the unexpected things you wouldn't think would be the problem! Glad you found it
exmotocrosser
Sep 13, 2019 06:12 AM
Scooter's Shop
23
Oct 22, 2015 07:04 PM
35dodge
Sep 29, 2015 09:40 AM
Matt123
Sep 29, 2015 01:29 AM
rgjackson
Sep 23, 2015 01:53 PM
