04 400ex question
Old Mar 31, 2013 | 12:33 PM
simplesid242002's Avatar
Default 04 400ex question
just got it, been riding for the past month now. when weather has been nice. anyway, yesterday I decided to change the oil. when I took filter out there was no spring. my question is, where can I get one ? and could I have done any damage running without it ? also the manual says 1.8 quarts, I put in 2 and still shows low. which is how I found out about the spring, reading articles here on how to change oil.
Old Apr 5, 2013 | 12:56 PM
ronaldraasch2000's Avatar
I dont have an answer for those questions officially.
But i would bet online has the spring or any off road warehouse will as well.
As for the 1.8 I believe it should be 1.8 per the manual. if you go and put to much oil a few things could happen it can burn off or some of the pressure in you engine may cause damage to some parts since there is to much oil and not enough air which causes unneeded pressure within the engine and possibly blow a seal. i would stick with 1.8 and if you change the oil filter you may need 1.85 but do what you think is best. im going to stick with the manual.
Keep me posted thanks
Old Apr 5, 2013 | 01:09 PM
budedm's Avatar
Those springs are $2.93 at DGY. Not sure what it does. Maybe just help remove the filter? Not sure. I'd get one if I were you though.
wendal
May 9, 2024 09:29 PM
bigred20653
Oct 2, 2015 10:05 AM
wendal
Sep 15, 2015 01:50 PM
XxS0ccerstarxX
Sep 8, 2015 06:54 PM
XxS0ccerstarxX
Sep 8, 2015 12:02 AM
