1999 xplorer 300 two stroke 4x4 wont start
Old Apr 10, 2013 | 02:11 AM
pjconstruction7's Avatar
Question 1999 xplorer 300 two stroke 4x4 wont start
Was riding along and it died electric start seemed locked up so tried pull start had to yank hard for it to turnover but no luck starting ... Got it home and checked for spark nd fuel both good ... what else could it be ??? Ive checked compression and is all good at 125psi.
Old Apr 10, 2013 | 02:36 AM
It died for a reason! You say it's getting fuel,but make sure there's no kinked lines,plus clean the fuel filter. If spark is still good as you say,fuel flow has been checked out,then it's possible you could have had a partial piston seizure even if compression is 125 psi. Just eliminate all the other things first.Plus it's not uncommon for the crank seal behind the front clutch to pop out. I've had that happen several times. This will kill one quick! Dirt Cheap Yamaha, Honda, Arctic Cat & Polaris OEM Parts & Accessories – Cycle Parts Warehouse
cornermike
Jun 3, 2015 07:27 AM
cornermike
May 27, 2015 10:04 PM
1000gade
May 27, 2015 12:37 PM
rsoxfan
May 30, 2000 12:23 AM
rsoxfan
May 28, 2000 03:27 AM
