Rim swap "Q"
Old Apr 17, 2013 | 09:15 PM
Norternguy's Avatar
Default Rim swap "Q"
Will 14" Polaris rims fit on an 06 700 twin efi sportsman that came stock with 12" rims.
I tried searching but its hard to be specific with a one word search.
Thanks
Old Apr 17, 2013 | 09:21 PM
Axton's Avatar
It will definitely grind against your overhead cover when you turn.
Old Apr 17, 2013 | 10:03 PM
Norternguy's Avatar
Is that because of the offset?
I am running 28-10-12 mudzillas on the front now.I am looking at getting new tires but what seems available used are all 14".
Not sure what all has been done with the bike,it was bought used.
All I know is it was driven hard and put away wet.Any maintenance was done only when it broke.
The bearings ,bushings and axles have all been replaced. The tires are killing the bike.I now have to weld some washers in the bushing bolt holes to straighten them out.They are all oblonged. They will be replaced when I find some in decent shape.lol
Old Apr 17, 2013 | 10:42 PM
Tonyxp's Avatar
The bolt pattern will be fine. If they are off of an xp sportsman they will have the right bolt pattern but the offset will be wrong. You would need wheel spacers for them to work. If they are aftermarket 14'' wheels for polaris they should fit. The common offset is 3-4 I believe.
Nosniborpapa
Sep 19, 2015 07:07 PM
cdoren
Aug 16, 2015 11:22 PM
toonces
Aug 12, 2015 06:42 AM
austinwhitton
Aug 11, 2015 06:21 PM
