differential fluid change
Old Apr 25, 2013 | 12:11 PM
mad-atver's Avatar
Exclamation differential fluid change
i am going to change diff oil in my 05 sportsman 500 for the first time but how much do both diffs take and when is it full? and do i use polaris oil in both? thanks
Old Apr 25, 2013 | 12:37 PM
mad-atver's Avatar
where is the drain plug for the rear diff? do i use polaris gear oil for it too?
Old Apr 25, 2013 | 02:14 PM
Look on the passenger side of the rear gear case and you will see a drain plug. When drained,the fill plug is located on the drivers side. Fill to bottom of threads. Use Polaris AGL only. Front gear case has a small 7/16" drain plug on the bottom. Fill plug is on drivers side at the bottom front of the gear case. Best if you have a fill tube or small funnel. Fill to bottom of fill threads,approx 5 ounces or so if I remember correctly.Use Demand Drive fluid only. #24 on each side. http://www.cyclepartswarehouse.com/f...2005&fveh=5659
#22 and #24 on the front gear case.http://www.cyclepartswarehouse.com/f...2005&fveh=5659
Old Apr 25, 2013 | 02:28 PM
mad-atver's Avatar
sare you saying use AGL for the rear and demand drive for front? is demand drive hub oil the same?
Old Apr 25, 2013 | 02:35 PM
Polaris AGL for the rear gear case(transmission) Demand Drive hub fluid for the front gear case(differential)
Old Apr 25, 2013 | 02:42 PM
mad-atver's Avatar
thanks alot! so rear diff/tranny share fluid?
Old Apr 25, 2013 | 03:01 PM
There's no rear differential so to speak like the 700 ,800 machines have that are separate units. The 500 gear case is one complete unit.
Old Apr 25, 2013 | 03:06 PM
mad-atver's Avatar
oh right lol when i put my finger in the hole should i feel fluid ?
Old Apr 25, 2013 | 03:15 PM
You should see the fluid come up to level with the fill threads, then stop and put the plug back in. As it says in the manual "fill to bottom of fill plug threads". Plus correction on the front gear case capacity on your model. Approximately 9 ounces versus 5 ounces on the older models,but still use the fill threads as the level indicator.
Old Apr 25, 2013 | 03:26 PM
mad-atver's Avatar
ok thanks for the help, i appreciate it alot!
MaasaiMomma
Mar 25, 2021 11:24 AM
Albertaboyy
Sep 9, 2015 09:51 AM
Jason Campbell
Sep 7, 2015 02:25 PM
twon1235
Utility ATVs
Sep 7, 2015 04:38 AM
Elkaholic
Sep 6, 2015 02:44 PM
